stock TA with moser 9 inch?????
will a stock torque arm work with a moser 9 inch? just wondering if it will change the pinion angle enough to cause vibrations. also the the TA will be mounted on the trans. i have a umi relocation cross member but i don't think i can use the stock TA, UMI crossmember and the 9 inch all together without getting alot of vibration.
