crazy idea of mine for boost...
My friend and I were talking and we had this idea. What if instead of hooking up a supercharger or a turbo you somehow hook up a pressurized tank to the engine? It could be like a scuba tank or something and would allow for a wide range of psi. A computer could even be hooked up to adjust how much pressure is released into the engine with throttle position. Advantages to this system would be no need for your engine to drive it, and it would probably be a lot cheaper, just fill up the tank when you want to use it. It would have to be short term though, maybe just a 1/4 mile run or two.
Has anyone ever heard of this idea? I tried searching a few places but I couldn't find any info.
but do you guys think it would even be possible?
and mods feel free to move this thread, im just curious to here other opinions
I'm not sure what happened to it but a few years ago a company called DEI (not junior) was in developement of a CO2 powered s/c instead of belt driven! It was meant to be a cheaper way of boosting the motor w/o any additional drag. The CO2 was sprayed into a sealed unit that would spin and compress the incoming air. I dont know what happened but the theory was sound IMO.
Doug
Why not? Many people go down the track w/ a pressurized tank its called nitrous or naws!
Doug
Doug
In a word.. no. There's not enough volume of air. It would work... or should I say 'could' work for about 15 seconds. However, you wouldn't see much boost because you can't move that much volume of air.
Scuba tanks are pressurized to 3000 psi. There's only a couple cu ft of air though. A s/c or t/c flows that every couple seconds.
The reason N2o works is the '2" part. It's 2 nitrogen molecules.
stick with hot chick pics...
edited.. thanks. was typing too fast and not paying attention.
The reason N2o works is the '2" part. It's 2 oxygen molecules.
The co2 powered S/C seemed to be an all around good idea, Just dont know what happened to it. I cant seem to find any info on it.
Doug
