Quick question?
Old 07-22-2008, 07:42 PM
jrock692's Avatar
Default Quick question?
Do I need a aftermarket MAF sensor? Ads claim 10-15 hp gain. But if I get a tune, will they be compatable. I have also heard do not waste the money. I am planning to add all bolt ons right now, and eventially a 383 build built for a little spray.
Old 07-22-2008, 08:10 PM
96LT1355Z28's Avatar
Don't waste your money just get a custom tune. some of the programers will reprogram your pcm for about $50 after the inital one for future modifications. So the initial bolt on tune and then one change later on and you've still spent less than buying a MAF that will flow more than you need.
Old 07-23-2008, 09:18 AM
ss.slp.ls1's Avatar
Don't waste your money, the stock MAF flows sufficiently. Spend your money elsewhere.
Old 07-23-2008, 11:16 AM
AChotrod's Avatar
Ive always had good luck, good ets and MPH gains with aftermarket MAFs. If you have the cash and everything else it cant hurt. I also dont think it is nessasary that you need one to go fast but it sure helps. In my 97 I had one in there put in a hotcam and had ed wright do the tuning and never had a problem. My 00 with minor bolt ons and one went 12.80s at 108
Quick Reply: Quick question?
