Purge Nozzle
Old 08-25-2003, 01:12 PM
z28mccrory's Avatar
Default Purge Nozzle
Im recently installed a TNT F2 kit on my H/C LS1. I also ordered the tnt 4an pro purge kit. Im wanting to somehow split the purge into two lines and run one out each side of where the windshield whipers lay. What kind of distribution blocks or whatever will i need, and where can i find the actually nozzles to put on the end of the lines so the purge will be very powerful.
Old 08-25-2003, 06:27 PM
Gregg 00SS's Avatar
Default Re: Purge Nozzle
Easiest way is go to Eagle Hardware. Go to plumbing section where they have all the fittings and find a -4an to I believe a 1/4" fitting. From that you can find a T that will split your line. I also ran steel braided line for the purge. I also got those from a plumbing store. They are high pressure lines used for refrigerators I believe. They have 1/4 connectors so they will screw right on. Most everyone just uses copper tubing for the end of their purge setup. Crimp the ends and it should give you a nice spray.
Old 08-25-2003, 08:10 PM
ApacheDrill's Avatar
I second the hardware store,i used cooper in my setup and didnt need anything on the end to make it more powerfull, it has plenty already..
Old 08-25-2003, 09:39 PM
Robert56's Avatar
Check out http://www.dynotune.org they have a billet aluim purge nozzle that is really trick and only cost 20 or 30$$.
Old 08-26-2003, 06:20 AM
Fast SS on TNT's Avatar
I bought mine from Dynotune. Its cool!
