Panhard Bar
Panhard Bar
Do you really need an on car adjustable panhard bar or is an regular adjustable one just as good. i thought you just make the enw one the same length before you put it on the car. am i wrong?
LS1Tech Premium Sponsor
Even from the factory the body is not perfectly centered over the rear end. If you lower your car you will need an adjustable pan hard rod to correct the body alignment. If you have any other questions please give me a call. I am in the office until 6PM EST Mon-Fri.
If the vehicle is lowered or you plan on lowering it at any time I would recommend the adjustable version... it will also come in handy if running a wider tire such as a 315. Adjusting the panhard bar allows you to center the rear of the car and prevent any type of tire rubbing.
If you have any additional questions please ask. Thank you!
Ryan
Ryan
LS1TECH Sponsor
The answer is no, you don't need on the car adjustable. Adjustable is adjustable... On the car adjustable is simply easier and quicker to setup, and for the $30 you spend you'll save a lot of time and hassle. What's your time worth?
http://www.stranoparts.com/partdetai...D=67&ModelID=7
__________________
LS1TECH Sponsor
Glad I could help!
__________________
