High Performance Pontiac - 427CI - 9 second F-body
Anybody read the article on the ls1 race car in High Performance Pontiac this month..? It did 9.03 in the 1/4 mile...
The use of parts seemed good - Callies crank = 4.0, LS6 ported heads, sheetmetal intake, ....
An intereted article on the Gen 3...a surpising thing considering the BS articles that have recently be published in other so-called hot rod magizines...
Re: High Performance Pontiac - 427CI - 9 second F-body
...they used a very small cam for a racer, however, - like a 224/224...with a 572/572 lift
Is this a misprint?
Is this a misprint?
...well the car did have a NOS setup ...the 1/4 mile stats were provided in the article in both modes, (i) naturally asirated, and (ii) on laughing gas...
...I would like to have a street car this bad *** ... you would totally rule the road..!!!
This one is red and has a C5R 427 motor (4.0 Callies crank)
...the owners have a speed shop in Jersey...it is called B-R Racing and it is located in Trenton NJ...apparently, they are not a sponsor...
The cam specs listed in the article are:
229/229, 578/578, 114LSA
They take you through the various stages of development starting with the stock displacement moving through the transition to the big 427...
..Is it possible that they got the earlier cam and not the cam that is running with the C5R block....?
...this cam seems too small for the big motor; right?
LS1TECH Sponsor
Guys, this car is owned by Buster Brashier. His shop is in NJ (Buster's Auto). It is an MMS 427 C5R Block and LS6 Heads. Runs a serious shot of NOS. I tuned this car for Buster. It's a strong car and has more there. Stay tuned...
Heck of a great guy too. I just hope I can get him on the light by a full second...
Mikey
Mikey
Mikey:
Can you confirm the published specs for the cam that is currently running in the 427 motor?
These hot rod mags are notorious for getting incorrect information.
...not to be critical ...but if the motor is an MMS and the tune was performed by Mickey then I assume Buster buys all his parts and labor from others....maybe he is good with wrenches, however...
Ok, heres to set the record straight. There are no misprints in this article, more specifically that is the correct camshaft numbers, also, robertbartsch, every little bit of work on this car has been done by myself and my son (other than of course the block). Secondly, yes it is Big Red from the East Coast. Also can't forget Mikey, he did an awesome job tuning, and is a cool guy as well. As far as numbers, you posted incorrectly, the magazine clearly says 9.31,and 145.8mph, not 9.03. And just so you know, we are currently doing an S/R conversion to run 8.xx's hopefully this fall. I don't normally post on sites, but i do read the messages.
Keep up the good runs!
BRracing if your done with your car
EFA in maryland is putting on a Heads Up race
in Oct at MIR
Mikey would know about it You should try and come down for the race . should be 100 or so cars
in Oct at MIR
BRacing:
Nice article, nice car, nice work.
Question:
Have you considered using a bigger cam or is the current cam the optimal stick for the big motor?
Question:
in Oct at MIR
in Oct at MIR
the efa race should be fun. i think i saw the big red car at maple grove. wasnt it next to you in the pits mikey?
back to the efa event....you 8 and 9 second cars are gonna run outlaw?? i want to have a chance with my little m6 car.
What is the advantage of a solid roller; i assume it can rev higher; right?
Is it also lighter and can have a more aggressive cam lobe...??
I suppose u need adjustible rockers too...
