Top end upgrade, stock motor
Old 08-26-2003, 12:31 PM
Moderator
jimmyblue's Avatar
Default Top end upgrade, stock motor
I've seen it said that the top end (springs?)
are the "first limit" to how high the stock
motor can safely be revved.
With minor intake improvements and a not-bad
exhaust, my engine doesn't seem to be "falling
down" the back side of the torque curve yet at
the 6KRPM upshift. Long term reliability concern
is what keeps me from pushing the shiftpoints
further upward.
So I'm wondering, would a simple springs upgrade
make it safe to hit 6500RPM on a daily basis?
Springs & rockers? What minimum upgrade componentry
would it take for a "close enough to bulletproof"
top end?
Old 08-26-2003, 12:46 PM
humanoidZ06's Avatar
Default Re: Top end upgrade, stock motor
In my opinion the weakest link is the rod bolts. I wouldn't feel comfortable winding the engine out to 6,500rpm daily with stock bolts. At the very least, I would upgrade the stock rods with ARP bolts.
I assume that you're still running the stock cam (since the springs have not been changed). If so, why do you feel the need to shift at 6,500? Have you had the car on a dyno to see where power peaks, and where the optimum shift point is? Every stock car that I've had on the dyno has peaked around 5,300 - 5,500. Beyond 6,000 the power drops off drastically.
