1/4 mile numbers??
1/4 mile numbers??
hey everybody, i got a 99 z28. so far i got slp loudmouth II's, lid and smoothe bellow. I have taken around 120 pounds off of my stock weight. What et should i be running with these few mods?
i'm sure i could hit high 12's right now just with some street radials. it's mainly a daily driver so a stall might be a little too much.. but thanks for the suggestion
i have an 2002 ss 6 speed, i was running 13.3 108mph. no modiications done at the time i had just about no traction off the line i was launching about 3000. rpm. start with a set of drag radials yes a converter will def help i wouldnt go higher than a 2500 stll for street use. if you do get a good trans cooler. and start saving for a rear now these arent the strongest, altho it could last but just in case.
i can see a 13.1 if you hook. otherwise probably 13.3-13.5 or so.
also the rearend will be fine if you don't let it wheelhop. i pulled MANY MANY 1.6x 60' on the stock rear with 373s and a dif cover. car had 45k on it when i bought it and i think 63k on it when i sold it. the last 15k miles weren't what you'd call easy haha.
