1/4 mile numbers??
Old Jul 29, 2008 | 02:48 PM
redbadss's Avatar
Default 1/4 mile numbers??
hey everybody, i got a 99 z28. so far i got slp loudmouth II's, lid and smoothe bellow. I have taken around 120 pounds off of my stock weight. What et should i be running with these few mods?
Old Jul 29, 2008 | 02:59 PM
Bizzles's Avatar
low 13s. A4 or M6? What tires?
Old Jul 29, 2008 | 03:30 PM
Pntbll309's Avatar
good solid 15.20's. Take it to the track and find out.
Old Jul 29, 2008 | 03:49 PM
krazy4's Avatar
If you have never been to the track before, don't expect good times but if your an A4 it isn't that hard. My guess is around 13.4-13.5 with a 2.2 60ft.
Good luck!
Old Jul 30, 2008 | 04:31 PM
redbadss's Avatar
alright thanks, but don't these cars run 13.3 stock?? yea mine is a automatic with 245/45/17's all the way around.
Old Jul 30, 2008 | 04:39 PM
udienow's Avatar
My buddy has nearly identical set up to you.
00 z28 with Loumouth cat back, and a lid. He has 275 wide tires tho.
He also took out about 100 lbs of weight last time at the track. He ran 13.5's all night long. His best is a 13.3. I wouldnt expect much better.
Old Jul 30, 2008 | 04:46 PM
redbadss's Avatar
Sounds about right, i've been to the drags and seen quite a few fbods. i'm looking to get in the mid 12's without heads/cam.
Old Jul 30, 2008 | 04:56 PM
udienow's Avatar
ur prolly gonne need a stall then. Idk much about autos but thats what I c everyone say as one of the best mods for auto.
Old Jul 30, 2008 | 07:00 PM
redbadss's Avatar
i'm sure i could hit high 12's right now just with some street radials. it's mainly a daily driver so a stall might be a little too much.. but thanks for the suggestion
Old Jul 30, 2008 | 07:06 PM
00MaroonZ28's Avatar
not gonna happen
Old Jul 30, 2008 | 07:08 PM
King Nothing's Avatar
depends also on your elevation and humidity . . . i got a 13.2 with lt's, full exhaust full intake on street tires and a a shitty 60' time so i'm thinking 13.4 or 13.5 for you and a stall will help you
Old Jul 30, 2008 | 07:09 PM
LS1 Terror's Avatar
stall it and you can expect those times mid 12's
Old Jul 30, 2008 | 07:14 PM
redbadss's Avatar
what rpm stall would i want if i got one? i would want to launch any higher than 2500 would i? don't wanna break the rear end.
Old Jul 30, 2008 | 07:16 PM
redbadss's Avatar
i wouldn't want to launch any higher than 2500(my mistake)
Old Jul 30, 2008 | 07:53 PM
LS1 Terror's Avatar
i would launch like at 1200 dont wana break the rear end
Old Jul 31, 2008 | 09:11 AM
jam01's Avatar
i have an 2002 ss 6 speed, i was running 13.3 108mph. no modiications done at the time i had just about no traction off the line i was launching about 3000. rpm. start with a set of drag radials yes a converter will def help i wouldnt go higher than a 2500 stll for street use. if you do get a good trans cooler. and start saving for a rear now these arent the strongest, altho it could last but just in case.
Old Jul 31, 2008 | 09:35 AM
tmaschm's Avatar
If a stall makes the street driving that much worse then why does everyone say get a stall and it will be more fun than driving a stick???
Old Jul 31, 2008 | 09:55 AM
Empatho's Avatar
don't waste your money with a 2500 stall you're only going to want to go bigger latter, get a Yank 3600 SS.
Old Jul 31, 2008 | 11:07 AM
s346k's Avatar
i can see a 13.1 if you hook. otherwise probably 13.3-13.5 or so.
also the rearend will be fine if you don't let it wheelhop. i pulled MANY MANY 1.6x 60' on the stock rear with 373s and a dif cover. car had 45k on it when i bought it and i think 63k on it when i sold it. the last 15k miles weren't what you'd call easy haha.
