2006 LS2 wiring ?'s
Old 08-06-2008, 11:32 PM
kochevy67's Avatar
Default 2006 LS2 wiring ?'s
I am currently instaling a 2006 LS2 from a GTO in my Chevelle. I have a few questions that I am hoping could be answered. I have the stock wiring harness, computer, trans controller and DBW gas pedal.
1. Can the computer be programmed to delete 2 of the oxygen sensors because there are 4 in the harness and I would only like to use 2 of them.
2. Also can the VATS be disabled so the car will run without stalling seconds later?
3. The current motor has a vent for the fuel system does the computer read that and do I need to have that hooked back up or can I do away with it and vent it at the tank?
4. And the last question is who does this?
Thanks guys.
Old 08-07-2008, 02:05 AM
beezer1519's Avatar
i'm pretty sure the rear o2 sensor can be deleted as i'm doing that next week when i go in for a tune.
any tuner that has experience should be able to tune some of the stuff to your specs.
Old 08-07-2008, 08:41 AM
wait4me's Avatar
I can set up your programming for you no problem, Give me a call and i can walk you thru what you need to do to get that thing running right.
Old 08-07-2008, 08:55 AM
kochevy67's Avatar
I will give you a call when I am ready. Thanks Wait
