Aeroforce Interceptor and Wideband
A few days ago I did some searches on how to hook up a wideband to a aeroforce. Could someone post up what is needed, or if its freakin involved?
I don't need to buy a wideband with a readout if I could get an aeroforce to do the same thing. What wideband would you recommend getting if this is how you wanted to do it?
Thanks
Thanks
check these threads out and see if they help:
http://aeroforcetech.com/forum/viewt...light=wideband
From what I could tell...they don't have an input for A/F directly, but it seems like some people got it to work. BUT they do have something coming out in August that will do A/F. Best bet would be to call them if you have a hole burning in your pocket and want to buy right away
Aeroforce is coming out with a gauge that will support Wideband O2 on-board, but it quite likely will be another 6 or 7 weeks before you see any progress on this item. I've been told that their into the 4th prototype unit and just need to iron out some details. You can use a wideband separately with this unit.
