MAP Sensor problem with HP Tuners
Old May 6, 2008 | 11:42 AM
dmw319's Avatar
Angry MAP Sensor problem with HP Tuners
My MAP sensor is not reading in HP Tuners it just sits at a constant value and doesn't move at all. I tested the sensor with a voltmeter and it read and worked as normal. from terminals A-C it read 5.02v and from B-C terminals it read 4.84v with ignition on and then 2.2-2.3v with car idling, just as it should! But it does not read in HP Tuners and im wondering if my engine PCM is reading it or not. anyone have any similar problems or have any advice? Thanks...
EDIT: my timing advance is doing the same thing. just sits at one constant value and doesnt change at all.
Old May 6, 2008 | 02:01 PM
dmw319's Avatar
i just emailed HP Tuners support...
also, with the key on.. the MAP reads 101... then when you start the car it goes to a random number like 65 or 90.. and just stays there until you turn the car off again.. and it goes back to 101....
Old May 6, 2008 | 03:01 PM
foff667's Avatar
LS1TECH Sponsor
Sounds like either a pcm or wiring issue to me.
Old May 6, 2008 | 03:13 PM
jimmyblue's Avatar
Moderator
Are you by any chance using one of the custom
multi-bar OSes? I don't know much about V6es but
see the hairdryer in your .sig picture. On the V8
multi-bar OSes there is a special MAP PID added
that you should look at instead of the regular. Can
you display MAP voltage in the scan tool?
Old May 6, 2008 | 03:25 PM
dmw319's Avatar
yes i can but i havent tried. what good will seeing the MAP voltage do?
Old May 6, 2008 | 06:14 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If you can read the voltage, then the problem is narrowed down to a setting in the scanner.
Old May 6, 2008 | 08:52 PM
dmw319's Avatar
hmm alright thanks guys i will check that tomorrow.
Old May 8, 2008 | 03:05 PM
dmw319's Avatar
its not reading the voltage either.
 Michael S. Palmer
Old May 8, 2008 | 03:42 PM
dmw319's Avatar
anyone?
Old May 8, 2008 | 05:34 PM
dmw319's Avatar
also i was getting the p0121 code but changed my max and min to 100 and 0 so now that went away. i read a little bit on how having a cam can sometimes effect that tps 0121 code.. i could try another TPS? would a bad TPS cause the MAP to be reading a consistent kpa??
also getting P1374
Old May 9, 2008 | 08:37 PM
dmw319's Avatar
nobody? i cant tune my car until i get this figured out!
Old May 17, 2008 | 11:15 AM
dmw319's Avatar
tried a new PCM today and it still has the same problem...
Old May 17, 2008 | 04:22 PM
jimmyblue's Avatar
Moderator
If the scanner can't see the real MAP voltage I'd
be looking for a wiring fault, chase the +5V and
GND all the way to the sensor, and the MAP
output all the way back to the PCM connector.
Old May 17, 2008 | 06:55 PM
dmw319's Avatar
its weird. it reads it as the car is being turned on and off but only momentarily then it sits at a constant value..
my car wont even start now. just cranks and cranks but wont turn over.
EDIT: tried a new ICM today also and still nothing.
Old May 18, 2008 | 03:40 PM
dmw319's Avatar
could it be the crank position sensor?
Old May 18, 2008 | 08:07 PM
edcmat-l1's Avatar
What map sensor are you using?
Old May 19, 2008 | 03:57 PM
dmw319's Avatar
stock
Old May 20, 2008 | 12:34 AM
dmw319's Avatar
tried a new crank position sensor today... still nothing. car isnt getting spark.
Old Oct 2, 2008 | 10:56 PM
adam`'s Avatar
did you ever find out the problem? i have this EXACT problem to the T.
Old Oct 19, 2008 | 12:55 PM
MikeyB's Avatar
i just done a cam swap my self and i cant get my map sensor to read in HP either
