Best for Daily Driver, 347 or 370?
Old 08-08-2008, 10:16 AM
Gandhi915EPT's Avatar
Default Best for Daily Driver, 347 or 370?
Well just purchased a turbo kit from OFI and was wondering what would be the best set up for a daily driver? I plan on running a nasty performance fuel system. The only reason I'm asking is because this is my everyday car and I need it to be reliable but still be able to make 700 plus hp at the push of the throttle?
Old 08-08-2008, 10:26 AM
LS1Tech Sponsor
hellbents10's Avatar
370 will get you there a little easier. Only down side really is weight of the iron block. What turbo do you plan on using?
Old 08-08-2008, 11:14 AM
cookba's Avatar
what about a bored and forged 346. that will get ya a 382 or 383.
Old 08-08-2008, 12:37 PM
I will be running g a tc76 with 60 lb injectors. I am getting the base kit. Would this size turbo be ok for a 383?
Old 08-08-2008, 01:12 PM
LS1Tech Sponsor
I would not go bigger then 346 then.
Old 08-08-2008, 04:32 PM
transamfreak01's Avatar
do you ever plan on going with more power? i would do a 370 and upgrade to a s85. make some nasty power
Old 08-08-2008, 06:07 PM
bboyferal's Avatar
Yup...
Stick with a forged 346.
Old 08-08-2008, 06:42 PM
EPP
EPP's Avatar
A 346 with a 4.0 stroke crank makes for a great combination, we've done quite a few of them. Bob
Old 08-08-2008, 10:03 PM
Websy21's Avatar
I agree but you will be limited with that turbo and a 383. Like already said, the 370 is the easiest and probably toughest but you have to deal with the extra weight. Thats what I decided on doing but now I am selling it before I even had a change to try it out
Old 08-09-2008, 11:03 AM
LS1Tech Sponsor
More cubes are defiantly only going to hurt power on that turbo.
Old 08-10-2008, 08:45 PM
bigd98's Avatar
go with 383!!
Quick Reply: Best for Daily Driver, 347 or 370?
