injector pulse width
I checked my injector pulse width because I want to upgrade my cylinder heads and was wondering how close they were to being maxed out.
My stock injectors are at 16.65 ms at 6000 rpm. I calculated that to be 83%. Is that right? I was suprized because I have a small cam and headers and stock heads. Will I need bigger injetors for ported heads?
well i am running my afr at 12.8 to 1 and my timing at 23 degrees total. its at the edge of pinging, the computer isn't backing off the timing but I can here the motor slightly pinging at full throttle on hotdays. (it has a quite exhaust). What injectors do you recommend for 450 rwhp?
