PCV coated wire?
PCV coated wire?
Where are you guys getting your PCV coated wire for your dual walbro installs? I have been to two parts stores and Walmart and no one has wire that can be submersed in fuel.
I'm also having trouble finding a Y to connect my pumps with. I have a big vacuum T I could use but it just doesn't seem like that would flow very well.
I had to go to aeroquip's website to find a part # and then ordered from Summit on the y block, sorry don't have it handy. The wire I haven't started looking for yet but NAPA should have it.
here it is AER FBM2179 .....$24.95
I found a Y block and some fittings that will work it will be like 50$ with shipping for the stupid Y block.
I find it hard to believe that everyone uses SAE 30R10 submersible fuel injection hose and PCV coated wire when they do their Walbro installs. It is damn near impossible to find submersible fuel injection hose. I've only found it on a couple sights and it is like 20-23$ a food + shipping.
I have not found ANY wire that states what it is coated with. I've looked parts stores and online.
I've found suitable wire at just about every hardware store I've been to. Just go to the aisle where they sell wire by the foot and look for the wiring that says right on the insulation "gasoline and oil resistant". However, I've always used regular fuel injection hose and regular old automotive wiring for pump installs. I've ran pump setups like that for over 120,000 miles with no problems.
The fuel injection hose the local parts guy gave me was SAE 30R9 fuel resistant but not made to be submersed. I guess I'll try my luck with it but I would much rather do this right the first time.
So can I just use some of the OEM wiring from the car? I have no problem cutting off a pigtail that went to the emissions crap that I've done away with.
