i sent my harness to lt1350.com, lt1wiring.com BAD
Old 08-08-2008, 03:42 PM
LUMPY85's Avatar
Angry i sent my harness to lt1350.com, lt1wiring.com BAD
i have let my project sit for about a year, i had sent my harness off my 2000 5.3 and 4l60e to lt1350.com, bad idea i think. there are no relays or fuses at all, all pinks are just bunched up into one 10g red, that says ignition hot. all the plugs i dont need: egr, second O2 sensor plugs, evap, and AIR stuff is still in the harness. i peeled back some of the wrap and there is a black wire with a white stripe just cut and in the open. Suggestions?? should i just go buy a painless harness and forget it. i dont know if i can even fix his mess. i got the entire wiring harness on my 99 wrangler all ready for my motor, i am just stuck on this piece of crap 5.3 harness.
Thanks
Ryan
Old 08-08-2008, 03:50 PM
mulletnotch's Avatar
PM Sent....
Old 08-08-2008, 03:56 PM
Jones'n's Avatar
There are a couple of budget harness companies out there that do just what you have described.
Cheaper isn't always better.
Old 08-08-2008, 04:00 PM
LUMPY85's Avatar
yeah i am finding this out, i am thinking i might go with painless. it is a big company and they have been doing it for years. the one thing i like is that i need to add wires to the loom for my lokar indicator and 4wd switch and i can easily just wrap it up in the painless harness while im at it.
Old 08-09-2008, 03:08 AM
loweredd's Avatar
That's how my LT1 harness was. I didn't have fuses or relays on stuff, but it worked with no problems. I dont know if this is different on the LS1 or not. I have seen quite a few swaps with relays and fuses for the other wires besides the computer plugs.
Have you read anything from people that have had a harness done by this company?
Old 08-09-2008, 07:27 AM
Jones'n's Avatar
If you look at a factory system, there are fuses for several circuits. Each injector bank, the MAF and O2's, the computer powers, and the transmission.
It will work without fuses, but if there is ever a problem, watch out.
Old 08-09-2008, 09:26 AM
bgblockelcamino's Avatar
i am surprised. i got my harness done from there and they did an awesome job. have recommended them for other too and had good results
Old 08-09-2008, 10:14 AM
Scooter70's Avatar
John at Speartech should be able to help you out. Give him a call.
Old 08-09-2008, 12:26 PM
LS1MCSS's Avatar
Thanks
Ryan
You definatly don't want all the hot wires hooked together into one. I use a small fuse panel from the local auto parts store. Fuses and relays are easy to add. Did you ask them to install the fuse panel and relays?
Old 08-09-2008, 02:45 PM
LUMPY85's Avatar
i assumed they would do it how everyone else did it. with the fuses and relays. i have decided i cant hurt the harness so i got alot of wiring info on this site and have completely disassembled the harness. i am currently weeding though the 2 pc connectors and extra emissions connectors that i dont need. if it doesnt work ill but from nelsons or speartech. they appear to both be nice harnesses, i like how the nelsons harness almost "hides". its very clean looking
Old 08-13-2008, 02:08 AM
JAYMACK3Y's Avatar
Default 95 Z28 Ls6 Swap
i am swaping a TL1 for a LS6, the z28 is all stock and the tranny is auto. what mods do i need to make including harness?
Old 08-13-2008, 08:32 AM
LUMPY85's Avatar
it would be way easier to start a new post about this instead of
Quick Reply: i sent my harness to lt1350.com, lt1wiring.com BAD
