Spark Problem
Spark Problem
I have a miss problem, it has started when it goes on the interstate. now it does it almost everytime I drive it almost quits. if u get on the interstate and go full throttle it misses bad. need help i have replaced the opti like 3000 miles ago with a gm ac delco one.
+1 on checking the wires as if you have headers and those wires touch just once it can burn thru to the core and then when accelerating the wire can move closer to the header causing it to arc and this will cause the miss you are seeing. Happens alot, check both of those first. If everything looks good, have your coil and ICM checked at your local Advance or AutoZone as they can tell you if they are bad. Let us know what you find and good luck.
