Ignition Switch??? WTH....
Ok, So my ignition switch went to boo boo sooo, I replaced it, and now I cant get my friggin car to turn on, crank, turn over, nothing.......How in the hell do you get this switch sync'd???? Yeah it's the PITA module on top of the steering column under the cluster, and has another round switch thingy with a metal rod that pushes it....anyone know WTH I'm talking about? me and this thing are
NVM, found the initial problem and man I feel like a putz......Popped the cover off my Fuse box under the hood to change a Fan relay and BAM....the ignition fuse was blow.....
Mine went out one time going down the Highway.. the hot wire off of the Battery coming in on one of the Terminals of the Switch got loose and heated up. It started melting through the blue plastic and eventually got to a piece of steel on the Column and Grounded out. The Car wend dead instantly cause it blew the Fuseable Link coming off of the Battery under the Hood.
It wasn't hard to trace..I was on my way to my GF's house and had to leave the Car on the side of the Highway for a night..I got a friend to give me a lift back to my house when it happened so I could get my Truck and go out with her. I got off of work the next day for a little bit to go get it towed.
$75 later(tow), $35 for a new Ignition Switch, $5 for the Blue Connector I clipped off of a Camaro at the Junk Yard, and a $3 10ga Inline Fuse it was Fixed..
