ls6 intake fins removal question..
ok i plan on installing the ls6 intake on my 98 z and i know u can used the stock coolant lines but where exactly do u have to grind down the fins.. can anyone post up before and after pics and wht they used to remove them.. i read u can used a wooden chisel and a hammer?? thnks guys for ur advice ...
The LS6 intake don't use the return to the rear, .The fitting on the rear are blocked off and the front is only a cross over pipe. The tube the goes from the front to the rear is deleted.You can get them from a GM dealer =
12551933 - Coolant Seals, Head: 4 each required
12602540 - Coolant Air Bleed Plug, rear: 2 each required
12602544 - Coolant crossover pipe, LS6: 1 each required
11517591 - Rear Coolant plug bolts (M6 x 1.0 x 30mm): 2 each required
__________________
__________________
just knock em all off raymond... I just did this over the weekend and it wasn't too bad despite me ripping my skin when I try to loosen/tighten the back bolts on the manifold. Click my screen name and look for my thread. Make sure you are very careful removing the intake/replacing with the booster hose since the oil sensor unit is in the way.
Gl man
Gl man
I just cut mine off after the Y in the front, and left nubs on the two back connections. Then I busted out the good 'ole JB Weld, filled the openings where I cut them off and crimped them. No leaks and it does the job with only $4 invested into the stick of JB Weld.
