first install, need any tips/pics i can get, (90mm plate system from nitrous outlet)
i am starting to install my kit,
i am a total noob in nitrous, my first install, so any install and tip you have is well accepted,
it would be grate to get some pics,
i am also installing a racetronix fuel system, so any tips there well accepted,
i have a fast90 manifold, Fast fuel rails, and Nw90 tb
thanks!
thanks!
Take your time and do it right, don't rush. Its is pretty straight forward run the main line either under the car or through the car under the carpet. I get to the engine compartment through the hole by the ecm by the glove box in that corner. Plan it out first or at least think about what your doing and how you want to look. You will be fine.
is there excsakt spot thats good for harder hit?
i am running fast90mm, and fast fuel rails w/fuel gauge, will i have to remove my fuel gauge?
FWIW, there are no holes to drill with the HSW either. They use the exisiting bolts that hold your Fast 90 to the motor.
I like having the solenoids seperate rather than clustered together like the N20 mount. Then again, it's your car, so its up to you to decide what you want.
Check out our customer page. There are a great deal of installs to look at in there.
This may give you some ideas.
http://www.nitrousoutlet.com/customerCars/index.asp
Our plate system is designed in a manner that it is very easy to have a nice clean isntall with out a huge messs of hoses draped all over your engine.
Dave
Dave
