HP Tuners x/y axis question
I'm trying to copy and paste a table in HP Tuners. The 2 tables I'm working with are reversed x/y axis of each other, so I can't just copy and paste the entire table. No matter what I highlight in the table, if I copy a row from one table it will paste in a row in the other table, even though I have selected a column to paste to, and vice versa. I hope this makes sense. Is it possible to reverse the x/y axis? I don't want to spend hours changing the values one at a time.
Do it in a spreadsheet. I'm pretty sure if you do some looking that there is one out there already made up to move back and forth between the two mainly to facilitate EFIL <-> HPT and vice vs.
Download the EFILive demo version. It has a conversion utility that lets you transpose the table axes. Getting the data in the table can be a little tricky but it can be done with copy and paste. I use it to copy and paste data between different tuning apps that have similar tables but transposed axes.
