Going To Manifolds For STS Need Help
Old 08-21-2008, 07:19 PM
vandal0-0's Avatar
Default Going To Manifolds For STS Need Help
Were are you guys getting your offroad y-pipe at that bolts to your manifolds.
Or should I just get a couple pipes made to go from my manifolds to my y-pipe I have now after I take the LT's off.
Thanks
Brad
Old 08-21-2008, 07:39 PM
RooRnZ28's Avatar
i have a bassani ORY that bolts up the stock manifolds, but it is not installed yet.... you should give it a looksee, as it seems like it would fit and flow pretty good. I have modified mine so that i can use v band clamps and am just waiting on my mechanic to get it installed.
when i first got it:
lol... its been in the same spot for 6 months!!
Old 08-21-2008, 09:29 PM
vandal0-0's Avatar
RooRnz28 were did you buy It from,and thanks for the pic.
Old 08-22-2008, 12:35 AM
witry's Avatar
or you can spend like 50 bucks and 4hrs and build one urself .... thats what i didnt and i have no problems with it hitting or ground clearance issues and while i was at it i wraped it for my rear mount
Old 08-22-2008, 08:30 AM
smoke20's Avatar
Bassanni off road Y -- it fits great no issue have been running it for the last 8 months.
Old 08-22-2008, 09:01 AM
xBROKEx's Avatar
why would you go from LT's to stock manifolds
Old 08-22-2008, 09:47 AM
vandal0-0's Avatar
The LT's lose way to much heat which causes turbo lag.Whith the manifolds they hold the heat In and there for the spool time Is reduced.
Old 08-22-2008, 10:43 AM
Zombie's Avatar
Because stock manifolds make WAY more power than LTs.
Old 08-22-2008, 10:47 AM
vandal0-0's Avatar
+1...
Old 08-22-2008, 12:19 PM
OUTLAWZ RACING's Avatar
That looks good man is it 2.5 all the way back? If so thats going to kick *** big time. I went from 3 inch to 2.5 and that made a big diffrance. But the only down side when you put manafolds and run straight through is LOUDNESS my car was way to loud and sounded like shizzle But a magnaflow bullet killed all the rasp
Quick Reply: Going To Manifolds For STS Need Help
