car just quit, possible fuel pump?
Hello, my car just quit running today while I was going to work, it will not restart. I think it may be the fuel pump. I moved the ignition swith to 'run' and checked for fuel on the schrader valve by depressing it, it squirted a bit then nothing. My question is should have fuel kept comming out of the valve while in run? Do i need to jump a relay, or something? Whats the best way to check for a bad fuel pump? The car tries to start, fires a little bit for half of a second but thats it. Any help is appreciated. Thanks
The easiest way that I can think of is; get someone to turn the key to run/acc. Go to the back of the car and listen to see if you hear the pump prime.Won't work if its too loud out side to hear this. $.02
I am having the exact same problem in my 94 Formula. It idols for like a second then just quits. The only way to keep it running is if I give it some gas.
I think it could be the fuel pump .
- Mike
- Mike
a security fault will keep it from starting as will a blown fuse.
it ran out of something spark fuel and compression is all it needs.
if you do not have much to work with a shot of ether could tell you something.
i have seen a bad IAC before where the car would run with my foot on the gas but as soon or shortly after i let off it would die out.
Close; air,fuel and spark is needed for an internal combustion engine.
Can the I.A.C.'s be cleaned off and ohmed to check them???
my car is having the same problem described here. I can turn it on and itll idle fine for maybe 3 seconds, then spudder, and sit at like 200 rpms and die. i checked the fuel at the rails, and im only getting 10 psi. So i guess the walbro i just put in my car about 5 months ago went bad. If you check the fuel at the rails, as stated above, it will narrow the problem down
first check the pressure at the rails....i was getting about 10psi so i put a new pump in, and still nothing......i thne took the fuel pressure regulator out tht sits on top of the bucket, blew a little dirt out of it, and it fired right up!
