harness adaptor 2000 Firebird Monsoon?
Old 08-27-2008, 02:52 PM
96AZHAWK's Avatar
Default harness adaptor 2000 Firebird Monsoon?
Does anyone have the Metra or Scosche part numbers for the wiring harness adaptor for a 2000 Firebird with Monsoon? Any help would be greatly appreciated. Thanks in advance.
I am having a hard time finding the adapter harness to add an aftermarket deck on my 2000 Trans Am with the Monsoon setup. I picked up two different GM harnesses and neither of them matches. One is the standard GM 88 and up harness and the other is a 2001-2006 gm harness.
Old 08-27-2008, 04:03 PM
pentavolvo's Avatar
its the standard 90s gm wiring harness. same one used in all 4th gen fbody or mid 90s cavalier etc. i find it hard to believe u cant find this as every autoparts store has em
metra 70-1858
Old 08-27-2008, 07:07 PM
96AZHAWK's Avatar
I have one of the standard GM harnesses, but it does not seem to work. On the back of the package it also states that it is for up to 99 firebirds. Is there a different one on 2000 and up models?
Old 08-27-2008, 08:49 PM
pentavolvo's Avatar
nope its all same harness.
what doestn seem to work about it
Old 08-28-2008, 01:31 PM
Ungrounded Moderator
WhiteBird00's Avatar
The factory harness has two 10-pin plugs. The standard 88+ GM harness adapter has one 21-pin plug. Put the two factory plugs together as they were when plugged into the head unit and they will plug into the 21-pin plug (the extra pin space isn't used). They are keyed to only work one way so if they don't fit, turn them over and try again.
Old 08-28-2008, 11:24 PM
freakish07's Avatar
Exactly what whitebird00 said.
Old 08-29-2008, 01:52 AM
96AZHAWK's Avatar
You are both right... and I am an idiot. Thanks for the help guys.
