harness adaptor 2000 Firebird Monsoon?
Does anyone have the Metra or Scosche part numbers for the wiring harness adaptor for a 2000 Firebird with Monsoon? Any help would be greatly appreciated. Thanks in advance.
I am having a hard time finding the adapter harness to add an aftermarket deck on my 2000 Trans Am with the Monsoon setup. I picked up two different GM harnesses and neither of them matches. One is the standard GM 88 and up harness and the other is a 2001-2006 gm harness.
its the standard 90s gm wiring harness. same one used in all 4th gen fbody or mid 90s cavalier etc. i find it hard to believe u cant find this as every autoparts store has em
metra 70-1858
metra 70-1858
Ungrounded Moderator
The factory harness has two 10-pin plugs. The standard 88+ GM harness adapter has one 21-pin plug. Put the two factory plugs together as they were when plugged into the head unit and they will plug into the 21-pin plug (the extra pin space isn't used). They are keyed to only work one way so if they don't fit, turn them over and try again.
