Fueling & Injection - Need help deciding on 42 lb. injectors
JScamaro
08-28-2008, 08:34 PM
I need some help deciding which brand of injector to go with. I know I need some 42 lb. injectors to supply enough fuel for my H/C and dry shot.
Originally I was going to get the FAST injectors but the price on them has gone up to $600-$700!!! That's crazy.
I done a search on most of the injectors available but I'm still undecided. The Racetronix injectors seem to be the least expensive but I'm also considering the Ford SVO injectors as well.
Should I be concerned about whether the injectors are flow matched? I've noticed some sponsors advertise flow matched and some don't.
What do you guys think I should go with? I already have a Racetronix fuel pump kit so I just need the injectors now.
SS1875
08-28-2008, 10:03 PM
I run SV0 42# injectors with my Racetronix pump, stock rails on my 383.
they were fine out of the box...however I did have them flow matched after a fuel incident. My engine builder did mine for $60.
Nasty N8
08-29-2008, 11:36 AM
The Racetronix injectors are flow matched already.
Nate
Racetronix
08-30-2008, 10:37 AM
We offer the 42's in both non-flowed and 1% flow-matched sets.
http://www.racetronix.com/621031.html
http://www.racetronix.com/621031FM.html
http://www.racetronix.com/product/Injectors/621031-t.jpg
Soul TKR
09-06-2008, 02:27 AM
bump... I'm interested in this as well...
blackls1ta00
09-07-2008, 02:02 PM
me as well will they support 650 hp ?with nitrous
Soul TKR
09-11-2008, 12:53 AM
bump again...
Racetronix
09-11-2008, 02:35 AM
:confused: ???
sk8co
09-12-2008, 01:14 PM
sorry new to injectors... flow matched meaning they will flow correctly on the stock tune? so a basic bolt with capability of flowing more than stock? just trying to clear some stuff up. thank you
calongo_SS
09-12-2008, 03:34 PM
No, you will need to tune regardless of whether you get them flow matched or not. Flow matched means that the injectors all flow nearly identically. There can be quite a variance from injector to injector if not flow matched.
kmspruill242
09-14-2008, 12:43 PM
Any benefit to upgrade injectors on just a bolt on car? Headers, LS6 intake, Underdrive pully. I use the car for road course duty so it sees extended high rpm use.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
