LQ4/LQ9 heads allow more P to V clearance than LS1/LS6/5.3?
Re: LQ4/LQ9 heads allow more P to V clearance than LS1/LS6/5.3?
yes the 6.0L heads have bigger chambers like 72cc or so, which would give you more p to v clearance but your compression will lower as well
I can shift faster than you.
No, PtV clearance will be the same between the 6.0l heads and the LS1/LS6 castings. Combustion chamber volume has nothing to do with this (at least not directly). It is how much is milled off the deck surface of the heads, valve size,etc. The 5.3 head will have better PtV on the intake side (1.89 intake valve vs 2.00 on the 6.0/LS1/LS6), but the it still retains the 1.55 exhaust valve as found on the other heads. Most people install larger valves in the 5.3l heads anyways while they are being ported.
Jason
Jason
My bad Jason I always thought the 6.0l heads had a higher deck which created the bigger combustion chamber, but maybe im just retarded
