Centering M9 help
Old 09-06-2008, 11:10 PM
proelky's Avatar
Default Centering M9 help
I was having issues with my M9 not being centered in the car so I purchased a set of Spohn Adj. LCA's. My question is where is the best reference point to measure center? I used the lower panel line to tire which was accurate, but when measuring from fascia to tire it's off by a .25". The pinion angle is set at -2 also. I'm just trying to get the suspension set for better traction and any help would be appreciated!
RR-frt 1.5", r 2.25"
RL-frt 1.5", r-2"
I'm assuming the rear point is not a good place for accuracy?
Old 09-08-2008, 04:10 PM
BMR Tech's Avatar
You are better off measuring to the front side of the wheel well to the metal portion. If you want to give me a call here at the office I would be more than happy to go over any questions you might have
Quick Reply: Centering M9 help
