Gears & Axles - 9in ?
View Full Version : 9in ?
95fbird
09-07-2008, 09:29 PM
Will a stock drive shaft work with the a moser 9in
Heyhoss93
09-07-2008, 09:38 PM
yes mine did all you need is the conversion u joint and you should be good to go
SS1875
09-08-2008, 12:08 AM
They will work but Bob @ EPP is now recommending 1" longer shafts on the 9" rearends he sells. heres a link to a thread about it.
http://www.ls1tech.com/forums/showthread.php?t=925437
EPP
09-08-2008, 04:38 AM
Here is the driveshaft I recommend for the harder hitting cars. Bob
http://www.exoticperformanceplus.com/performance_parts/index.html?item=541
AFASTYZFR1
09-09-2008, 06:30 AM
I ran my stock driveshaft 4 about 100 miles....then upgraded to a PST shaft......you should prably just grab a PST shaft from EPP.......if your stock one breaks, who knows what it will take out with it
