Will a drive shaft out of 98-02 Fbody work on 67 camaro?
Old 09-09-2008, 10:34 AM
UNmolestedTA's Avatar
Default Edit: Should I shorten my drive shaft or use a 4th gen on a LSX 67 camaro?
I am doing a LQ9 swap plus t56 into my 67 camaro. Will a drive shaft out of 98-02 Fbody work?
Last edited by UNmolestedTA; 09-09-2008 at 08:41 PM. Reason: to reword my question
Old 09-09-2008, 11:31 AM
Havok2's Avatar
not that i know of.
only 82-02 are interchangeable on fbodies.
diff rear end, and yolk i think
Old 09-09-2008, 12:17 PM
Rodder's Avatar
And wrong length too
Old 09-09-2008, 04:04 PM
ACONLP's Avatar
you can all so use a turbo 350 yoke up front. thats what i did.
Old 09-09-2008, 08:43 PM
Thanks for the replies and help. I purchased a drive shaft out of a 99 Fbody but I haven't saved enough $ for my LQ9/t56 yet. I know that I will need to use a shortened drive shaft for this combo. Has anyone tried this before or is this drive shaft too short/long? Thanks.
Old 09-09-2008, 09:06 PM
thunderstruck507's Avatar
for some reason with my BRP mounts and still moving the frame mounts back about an inch, my driveshaft I used with my 700r4 and 350sbc is now too short
it makes no sense to me, especially since the crossmember mounted back in the same place as with the 700
Old 09-09-2008, 09:29 PM
Rodder's Avatar
never heard of anyone using the 4th gen driveshaft in a swap. Everyone either shortens their 1st gen driveshaft, or gets a custom driveshaft made. The 1st gen driveshaft is about 49 1/2" between the ujoint centerlines, and the tdriveshaft for an LSx/T56 swap is probably in the range of 3-6 inches shorter depending on which engine mounts you use.
I think the the 4th gen shaft is around 41", so you'd have to replace the tube... not a big deal, but the 4th gen also has the wrong ujoint size for your rear end.
Old 09-09-2008, 09:31 PM
Rodder's Avatar
If it's like the F-body, BRP moves the engine forward something like 2 inches compared to an SBC. If you moved it back an inch, your 700R4 driveshaft should be close to an inch too short.
Old 09-10-2008, 01:47 AM
pist0lpete's Avatar
LS1Tech 10 Year
Well the math you have there works roughly but you also have to take into account the fact that the relation of the crankshaft flange to the bellhousing flange on a LS engine is different than a sbc. If you are using a 4l60 then the tranny would in fact be moved forward a bit because of this.
Old 09-10-2008, 10:15 AM
Shawn MacAnanny's Avatar
There is no way the driveshaft fits. I checked it out. From what i ordered i think my driveshaft was 48" and i think a 4th gens is only like 44" or something. I used a Dennys nitrous ready drive shaft with 1350 u joints and a 30 spline shaft and got it for like $500 with a lifetime warranty.
Old 09-10-2008, 10:36 AM
Eric Anderson's Avatar
Just for the info...I paid $206 for a modified used drive shaft.
This was for my A body LS1/4L60E swap
I provided a TH350 yoke, the shop provided the used but nice condition shaft, installed the yoke to proper length, installed new U-joints and balanced the unit.
I've still got the aluminum drive shaft from the 02 WS6 donor. Is that worth anything to anyone?
Eric
Old 09-10-2008, 10:45 AM
Stu Cool's Avatar
Eric,
Put that aluminum shaft up for sale in the Sales Department or on EBay, it is a desirable piece.
I paid $125 to have my existing shaft shortened and balanced. Then ended up not using it because I went to a 2 piece shaft, but that's another story.
Pat
Quick Reply: Will a drive shaft out of 98-02 Fbody work on 67 camaro?
