diagnostic trouble codes
hey what up fellas. i recently plugged in my hypertech on my car and pulled up these codes. i checked on this site, http://www.aa1car.com/trouble-codes/ , and this is what it came up with...
P0463: fuel level sensor circuit high input
P1626: anti-theft system fuel enable circuit (passkey error)
so does anyone know how to fix these problems and how much can i get a fuel level sensor at the dealer?
the anti theft code is because your ignition is going out, either the tumbler or the wiring is damaged. as for the fuel level thing, try checking all the grounds and making sure everything is right. and as for the price, you got to call
Fuel level sensor changes resistance based on fuel level. When fuel tank is full, Sensor resistance is high. PCM monitors changes on signal circut to determine fuel level. This information is sent to fuel guage.
If PCM senses fuel level signal voltage greater than 2.9 volts, DTC P0463 sets.
And as for the p1626 I need more info, Dose your car start?
alright thanks man...do you happen to know of anyone that can check out that problem for me. at the moment the car hasn't given me any issues with starting. overall the car doesn't give me any issues.
