walbro 320
walbro 320
does anyone have any information on this fuel pump and where to buy it. i cant seem to find much on it but was told it would be a good choice instead of two 255s. thanks
ok. i called the guy that tunes my car that recommended that pump. he said the are availible but unsure of a dealer. anyway he seems to think now a single 255 will be good for around 650rwhp with a alky control kit, 42# injectors and around 11# of boost. does this sound correct?
i already have 42# injectors and was planning on going bigger but if i dont have to im not. my tuner is making over 700rwhp in his vette with 42# injectors and alkycontrol, and since the metanol would be additional fuel i understand why i may not need bigger injectors and the duel fuel pumps. i'd really like to not run two thats why i asked about one larger one.
What do you mean you do not want to run 2 you are relying on a second fuel system to get you where you need to be with the Alky kit. Why not have one complete fuel system that can support your hp without wondering if your alky tank is full? Our dual pump kits are 100% reliable.
Nate
Nate
thanks for the response. well i do not plan on making over 650 to the wheels. i was looking at your set ups and i looked to me that the stage 2 kit was still using one pump. also if the car is tuned to run with the alky control wouldnt i have to make sure it is always full anyway?
