What is this and how do I stop It from leaking?
Old Sep 6, 2008 | 02:59 PM
WhiteFormula98's Avatar
Default What is this and how do I stop It from leaking?
I went to put on my fuel rail covers and this started leaking after i put it on, it's the metal piece on the fuel line ....
Old Sep 6, 2008 | 06:05 PM
Soul TKR's Avatar
can't really tell from the pic... but it kind of looks like a sender of some sort... you have any aftermarket guages in your car?
Old Sep 6, 2008 | 06:12 PM
no....
Old Sep 7, 2008 | 12:43 AM
scottie dont's Avatar
fuel line quick connect. go to the parts store. buy a removal tool for quick connect fuel lines and see if there is anything in there that can cause a leak.
Old Sep 7, 2008 | 11:18 AM
Where do i get the part for it?
Old Sep 7, 2008 | 11:51 AM
advanced, autozone, orielys, whereever you buy your tools/parts from
Old Sep 7, 2008 | 03:03 PM
poconojoe's Avatar
Push it and pull on it to make sure its seated
Old Sep 13, 2008 | 04:45 PM
TODDS93T/A's Avatar
i bet if you look down in there one of the rubber o rings is missing i have saw them fall out when you remove the fitting if you havent moved the car look around with a flash light see if you see laying around i am almost positive that is what happend
Old Sep 14, 2008 | 01:05 PM
Monello's Avatar
Mine is doing the same thing. let me know if you find a parts department that sells the oring or connector.
Old Sep 14, 2008 | 01:28 PM
Its the metal piece inside.....theres no o ring.....I even checked my brothers which is actually not leaking and there is no O ring....prolly just need to order fuel line from dealer
Old Sep 14, 2008 | 01:40 PM
Does any one know where to get the metal piece inside the quick disconnect?
Old Sep 14, 2008 | 07:27 PM
Monello's Avatar
I just went to NAPA and they had GM quick disconnects in 3/8 and 5/16.
The feed for our cars i think is a 3/8. These do have the plastic oring inside of them. I will see if I can snap a few pics tonight.
Old Sep 14, 2008 | 09:25 PM
Monello's Avatar
Here is a pic of mine. Notice inside that behind the orange thing its just metal, an empty place.
Here is what came out of mine.
Notice the new one has a yellow/clear plastic oring inside.
The old one next to the one i found at NAPA
What do you guys recommend I do? Cut off the old end and put it on that hose, or replace the entire hose, with new ends on both side. What type of hose do I buy?
Old Sep 15, 2008 | 11:19 AM
WYATT318MOPAR's Avatar
That Hose Actually Comes Apart A Little Further Down That End On The Engine Is Only The Extension...i Think I Have A Spare One Laying In My Shop..or You Can Get One At The Dealer...i Wouldnt Run A Spliced High Pressure Line Unless I Wanted To Burn My Car To The Ground.
Old Sep 16, 2008 | 10:10 AM
Monello's Avatar
So the stock quick disconnect actually comes out if you pull hard enough!
The replacement I bought is identical, except that it doesnt have the curve in it.
Here is the new one next to the stock one before I installed it.
Old Sep 16, 2008 | 05:12 PM
[QUOTE=Monello;10117042]So the stock quick disconnect actually comes out if you pull hard enough!
I HAVE NEVER SEEN SUCH A PIECE....HAVEN'T TRIED TO INTENTIONALLY PULL THE END OFF OF MINE EITHER THOUGH...SO HOW DID IT GO GET DROWNED WITH HIGH PRESSURE GASOLINE SPRAY OR DID IT ACTUALLY ALL SEAL UP AND WORK LIKE IT WAS SUPPOSE AND NOT CATCH EVERYTHING AROUND IT ON FIRE???
Old Sep 18, 2008 | 09:56 AM
Monello's Avatar
Its the exact same piece that GM uses, except for the bend in theirs.
NAPA sells them.
Pull it out, and put the new one in. Simple as that.
