mounting rs body kit
I'm considering buying a rs body kit from a guy on here, but he is missing some of the mounting brackets.
how can I mount it if I can't find any more of them? A friend of mine who used to have a 98Z28 with the kit said that you can just screw it in and use some two way tape, but that seems rigged up and I don't want it to look like crap
You might be able to buy the brackets from GM. If not double sided body tape and some black push pins should do the trick. That is how most aftermarket kist are attached. It will look fine.
your friend seems to know an awful lot about things....... you should just listen to him.....he would never give you bad advice or settle for anything less than the best
