Zmax Dragway Pictures
So with the new drag strip being right across the street, so to speak I HAD to go. My father and I went on sunday for finals.
We have been long over due for a "Nitro Fix" as we call it. So he came down sat night and we were at the track first thing Sunday morning. The track is amazing, Bruton really out did himself. Now we will just have to see if he is willing to do some test and tune nights...
Here are some shots.
Ill start off with some good ol' Fbody's
The rumor is that the speed limit is 350mph. When they hit that, the insurance company that they are with will no longer insure them. Mind you the insurance company they are with is the only place that will insure them...
Until other changes are made, they will continue to only run 1000 feet.
-bryan
Thats all I have of Ashley. Couldnt get that close to the Force pits. There was always a mob of people around it.
Thanks for the compliments guys!
-bryan
Yeah I wish.
I might have some more pit stuff. Not so much on building them though. They were trashing while Funny Car, Prostock and PS bike were running. So we missed most of that.
-bryan
-bryan
If your not familiar with Top Fuel...
One Top Fuel dragster 500 cubic inch Hemi engine makes more
horsepower than the first 4 rows at the Indy. 500.
* Under full throttle, a Top Fuel dragster engine consumes 1 gallon
of nitromethane per second; a fully loaded 747 consumes jet fuel at
the same rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to
drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on
overdrive, the fuel mixture is compressed into a near-solid form
before ignition. Cylinders run on the verge of hydraulic lock at full
throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the
flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above
the stacks at night is raw burning hydrogen, dissociated from
atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output
of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2
way, the engine is dieseling from compression plus the glow of
exhaust valves at 1400 degrees F. The engine can only be shut down by
cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds
up in the affected cylinders and then explodes with sufficient force
to blow the cylinder heads off the block in pieces or split the block
in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate
at an average of over 4G's. In order to reach 200 mph well before
half-track, the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to
light!
* Including the burnout the engine must only survive 900 revolutions
under load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew
worked for free, and for once NOTHING BLOWS UP, each run costs an
estimated $1,000.00 per second. The current Top Fuel dragster elapsed
time record is 4.441 seconds for the quarter mile (10/05/03, Tony
Schumacher). The top speed record is 333.00 mph (533 km/h) as
measured over the last 66' of the run, (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are riding the average $250,000 Honda MotoGP bike. Over a mile up
the road, a Top Fuel dragster is staged and ready to launch down a
quarter mile strip as you pass. You have the advantage of a flying
start. You run the RC211V hard up through the gears and blast across
the starting line and past the dragster at an honest 200 mph (293
ft/sec). The 'tree' goes green for both of you at that moment. The
dragster launches and starts after you. You keep your wrist cranked
hard, but you hear an incredibly brutal whine that sears your
eardrums and within 3 seconds the dragster catches and passes you. He
beats you to the finish line, a quarter mile away from where you just passed
him.
The dragster spotted you 200 mph and from a standing start not only caught,
but nearly blasted you off the road when he passed you within a mere 1320
foot long race course.
Thats acceleration!
throttle.
in half.
light!
under load.
him.
Thats acceleration!
