compression?
Old 09-16-2008, 09:54 PM
hawk584's Avatar
Default compression?
what compression should i run if i deside to sell the turbo and go all motor? i have a forged 385LT1 currently running 9to1
Old 09-16-2008, 10:18 PM
NSTIGATR's Avatar
you wanna run pump gas or race??? this gonna be a DD or weekend warrior??
Old 09-17-2008, 07:57 AM
Internet Mechanic
BlackScreaminMachine's Avatar
as far a mechanical comp, 11.25 to 1 wasnt an issue for me. LT4 Hotcam, CNC ported heads, LT1 casting, stock sized valves, 6" rods.
Old 09-17-2008, 07:59 AM
NicksTAgt's Avatar
I would go in the 11:1 range if you are planning on driving it alot, more if its just a toy.
transamws6_97's Avatar
pretty sure i've seen setups of guys running 13:1 with pump gas
Old 09-17-2008, 08:44 AM
slomarao's Avatar
11.6.1 or 11.8.1 , Just under 12.1 is what i would do.
All the extra hassle with 12.1+ isnt worth the extra 5-10hp. Plus it makes tuning the car a total bitch.
Old 09-17-2008, 08:50 AM
hawk584's Avatar
DD on 91oct.
Old 09-17-2008, 12:32 PM
Dave J's Avatar
11:1 is good and safe
Old 09-17-2008, 12:35 PM
z28rob18's Avatar
wit pump gas i wouldnt go over 11:1
Old 09-17-2008, 02:22 PM
connexion2005's Avatar
I'm currently running 12:1 on 93 octane and the knock is minimal. I'm getting a slight bit of retard in the mid range and I'm working on tuning it out. Bottom line is static compression is not what you should be looking at but rather dynamic compression is the important one.
I'm running right at 9:1 dynamic compression...
Quick Reply: compression?
