69 Impala swap done..
There is a FAQ on how to post images..
What I do is, post them on Photobucket, then copy the HTML tag for a Image and then embed it into the post/thread using the Insert Image icon or just paste it in.
If you don't want to use a Photo or Image hosting site, then you can also do a "File Attachments" using the "Manage Attachments" button from the Advance editting page.
This is a 5.3 Ls1 from 02 tahoe. victor jr. intake with 600 holley carb. 6010 msd box and hooker block hugger headers. had to bang the two middle pipes on the driver side to work with ps gear box. used conversion mounts fron CAR SHOP INC. and solid sbc mounts. bolted to th 350 tranny. used hughes spacer from summit and stock flexplate (with holes opened inward 1/8th in.) thanks to everbody on here that gave usefull info. and big ups to CAR SHOP INC. for posting the pics and the good mounts i bought.
Now if any body has a F Boby oil pan, pick up, and windage tray and some valve cover bolts (need 1) thanks
1969, 53, 69, conversion, generation, impala, impalapickup, implala, ls, ls1, ls1tech69, suspension, swap, swapping
