Installing an LM-2 Wideband, have question????
I have an LM-2 Wideband and want to install it on my OBD1 Firebird with a 3.8L GN motor swap. Can I install this on an OBD1 setup?
The LM2 package and instructions only show OBD2 stuff and I dont wanna tear all the analog wires up by splicing into no mans land!!! Any help or advide would be great!
Thanks,
Chris
Thanks,
Chris
I don't think you will be able to use the OBD-II scan function of the LM-II. Your OBD-I car does not have half the smarts the LM-2 needs.
You can still use the wideband and all the external data logging functions though.
Without going through all the manual, it seems all you need to do is connect the sensor and the power cord. Hook it all up, calibrate the sensor (if it doesn't do it automaticly) and you are good to go.
Remember that you must always start the unit before the engine. Never run the engine with the sensor in and the unit off, that KILLS the sensor.
Thats it? Lol, I can build motors, diagnose cars, wire up just about anything but I cant even figure out a plug and play Wideband? Im gonna go back to school!
Thanks! Ill have to try it out!
