LT1 wiring harness pinouts
Old 09-22-2008, 06:33 PM
jebcamaro's Avatar
Default LT1 wiring harness pinouts
I am looking for a source to obtain the pinouts of the engine wiring harness from a 97 camaro. Any help would be greatly appreciated
Thanks
Old 09-22-2008, 08:21 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Alldata. Type it into google. You'll have to pay a subscription price for a year, but it is worth it. It'll show you everything you could possibly need to know about your car. You could also find someone who has it and will let you print things out. My friend has it at his shop and I basically ran his printer dry.
Old 09-22-2008, 08:43 PM
fergymoto's Avatar
These are for 1995 but most everything is the same other than some emissions controls and the crank sensor.
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_wiring
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts
Old 09-23-2008, 10:11 AM
jebcamaro's Avatar
I am retrofitting a 97 harness into my 67 camaro. I am wondering, can I remove all the VATS wires to eliminate vats or do I need to keep them in there and just reprogram the computer to remove vats? The computer has to be reprogrammed anyway though
Old 09-23-2008, 10:16 AM
fergymoto's Avatar
You can remove them all but the only thing that will actually get rid of VATs is to have it disabled in the PCM.
Old 09-23-2008, 10:36 AM
jebcamaro's Avatar
I understand that, but just wanted to make sure I coudl remove all the wiring from it as well.
Thanks
Quick Reply: LT1 wiring harness pinouts
