ms4 and 408 with stg 1 243's guess on my numbers
Ok so i had a spun rod bearing. I tried finding a good stock cube rebuild kit for cheap but couldn't so I decided STROKER. First i was looking at the 383 through texas speed. But then chris with CCperformance made me a great deal on an Erik Koenig built 408. I am runnig the MS4 on a 111.5 lsa with stage 1 ls6's from texas speed. I also have all of the basic bolt ons ported tb, lid, full exhaust with lt's, ud crank pulley but i have the stock ls6 intake. The engine will be right about at 10.8:1 cr and im running the stock 3.42 gears in my 10 bolt through an M6. I will be getting it tuned shortly what do you think I will put down on a md with a good tune? sorry for the length.
Brandon
Brandon
MD~450-460RWHP
Dynojet~480~RWHP
With a 90/90 setup you should clear 500~ on a dynojet
Mill the heads or run some cometics get the setup to 11.2-11.5 compression and the car should make 500 all day
Dynojet~480~RWHP
LS1Tech Premium Sponsor
Should look similar to the graph in the thread below after you get the FAST intake.
https://ls1tech.com/forums/dynamometer-results-comparisons/970307-tsp-402-w-ms3-stage-1-ls6-heads.html
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Maybe 470-480 with a fast 90/92 on an honest reading dynojet and about 440-450 on an honest reading Mustang Dyno. Can't really relate to anything else that has their numbers corrected to "read like a dynojet" on other brand dyno's.
That car made 500rwhp on a dyno dynamics which supposedly reads 10-15% lower than a dynojet. Not doubting the cars performance but too many people just see the number and overlook the fine details. Im sure those numbers were corrected to "read" like a dynojet but it still isn't a true accurate comparison IMO.
My car was dynoed on the same dyno as fifedogg.
I wouldn't say the numbers my low
You're already missing the crucial FAST intake.
Your exhaust might be less than ideal as well.
If you had all the UPgraded bolt-ons, you would see WELL in excess of 5xx rwhp and a LOT of torque
LS1 Tech Administrator
You are free to start a new thread after you have some results. This section is for dyno results and comparisons, not guessing games. That's better suited for the Gen 3 internal section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
