FM14 Cam / True Duals , start up - Good Quality Clip
Old 09-28-2008, 11:33 PM
ineedashortblock's Avatar
Default FM14 Cam / True Duals , start up - Good Quality Clip
Very boring video guys... but its very good quality to show the sound on this setup.
Motor is a forged 347, FM14 232 / 234 .598/.600? 112lsa cam. LT headers to a custom 2.5" True dual system with dynomax bullets
Cold start, so the idle is a bit high.
http://www.youtube.com/watch?v=puve_ONYHOI
And I am adding a second clip:
http://www.youtube.com/watch?v=JpVANM6tF0A
Old 09-28-2008, 11:41 PM
RAZORS10's Avatar
Sounds good man i'm going with the Ms4 cam from TSP. Keep up the good work. Whats your goals for the car?
Old 09-29-2008, 01:35 AM
10's, cam only forged 347... and then spray it as much as it will take. We'll see if the new found 3150 - 3200 raceweight can help me get there.
Old 09-29-2008, 06:55 AM
Reject's Avatar
nice, what rims are those? sometimes i miss the rough idle of NA, but then the turbo whistle reels me back in
Old 09-29-2008, 08:33 AM
99zee's Avatar
Sounds nice.
Old 09-29-2008, 11:41 AM
Detoxx03's Avatar
Sounds killer
Old 09-29-2008, 11:59 AM
Breathtaker's Avatar
Sounds great, problem with your right headlight?
Old 09-29-2008, 12:55 PM
Kingc8r's Avatar
^ Beat me to it. Sounds good
Old 09-29-2008, 02:16 PM
I was setting up the wiring for the black halo's I've got, just haven't had a chance to finish it.
Old 09-29-2008, 02:18 PM
Fronts are MT ET Wheels. Bought them off a friend, but they are about 300 / wheel new I do believe.
Rears are cheap - o summit stars, which are weld pro star knockoffs. They look good for 99 / wheel though.
Old 09-29-2008, 04:08 PM
Added a second clip, it's a little better than the first.
Old 12-12-2008, 08:09 AM
small bullitt's Avatar
wow, you sound alot different in this forum then you do in import atlanta forums. you seem more humble
Old 12-13-2008, 07:17 AM
TT90Coupe's Avatar
Shane is a good guy.. There is a difference in trying to get races started and just sharing/showing the car he built.. People dont understand that **** talk is exactly what it is **** TALK... Not ment to be taken past the point of the subject at hand.. Once past that subject everything is normal...
Old 12-15-2008, 09:24 AM
i understand what you're saying, but calling out cars that are not generally fast and down grading them is cool if you will answer the call outs people give you. he prays on the weak but cant back up his talk when someone equal to him (small 4-cyclinder) steps to the plate......dont know the guy personally, but thats his impression on the other forum
Old 12-21-2008, 10:42 PM
lilbuddy1587's Avatar
Take your bull **** out of here.
Quick Reply: FM14 Cam / True Duals , start up - Good Quality Clip
