fuel press on spray?
Just up'd my shot to a 150. I have a in tank walbro 255 and when I hit it I went down to 50psi. Is this still good to spray on? It pretty much dropped 10psi cause it will normally sit about 60 psi when Im driving. A/F was kind of rich at 10.9-11.2ish aswell...
no, it should NEVER leave 58. when u hit it at first it should drop a few lbs but should come back up..
but it on a dyno to check it. or run a hose up ur cowl of the windshield and put a gauge on the end of it, take it to the streets and hit it.
Nick
.25 fuel .46 N20 for the pills Im running from TNT. Under load N/A it will drop to 58psi or so and A/F is at mid 12's to high 12's on the top end. I think it comes up a little under load when I spray. I need to do more logging cause I just put the 150 shot pills in and I really dont spray the car very often. I did do a quick hit on it today to see where it was and the A/F was at low 11's on the juice so that seems ok. I just got retuned recently and were still tweaking the tune, I also just put new 02 sensors in because my right one was intermediate and now with the new ones that may be affecting my tune making it run a little richer since it was intermediate when I got it tuned. Looks like Im gonna have to step up and do the hot wire kit and get the tune tweaked a little...??
