Nitrous noob....what caused this?
Old Sep 29, 2008 | 08:14 PM
BRAKE's Avatar
Default Nitrous noob....what caused this?
These are a fresh pair of tr6's, I pulled them out of cylinders 5,7 and 6,8, is this detonation? If so what causes it, lack of fuel, too much timing, plugs not gapped properly? I'm running a 150 shot, jets .062 N and .033 F btw.
Thanks in advance.
Old Sep 29, 2008 | 08:17 PM
bad6as's Avatar
whats the total timing on n20?
Old Sep 29, 2008 | 08:20 PM
BRAKE's Avatar
24*
Did I do any motor damage?
Old Sep 29, 2008 | 09:09 PM
ATVracr's Avatar
TR6 and to much timing = trouble
Old Sep 29, 2008 | 09:21 PM
BOTTLEFEDLS1Z's Avatar
Did you pull any timing for the spray or what??
Not a good sign though...
Old Sep 29, 2008 | 09:44 PM
BRAKE's Avatar
Yea I pulled 6* so Im at 24* total timing.
Old Sep 29, 2008 | 09:46 PM
BRAKE's Avatar
Should I be running a plug other than the TR6's?
Old Sep 29, 2008 | 09:48 PM
camscam02's Avatar
aftermarket fuel pump?
Old Sep 29, 2008 | 09:55 PM
Need to pull more. Whats the A/F? was the car tuned?
Old Sep 29, 2008 | 10:27 PM
ATVracr's Avatar
When you spray the car yes.
If you melt the ground straps off its a timing and heat issue.
I'd go 2 steps colder on the plug and pull 2* more timing.
Old Sep 29, 2008 | 10:44 PM
Ls1Gummi's Avatar
What do you mean by going 2 steps colder??? Btw I'm having the same problem. Walbro pump 22*deg timing running off the stock rails
Old Sep 29, 2008 | 10:59 PM
quik406's Avatar
What fuel??
Old Sep 29, 2008 | 11:12 PM
Ls1Gummi's Avatar
I dont know about BRAKE but i'm runnin pump gas
Old Sep 29, 2008 | 11:21 PM
Rob's 02 SS's Avatar
When i chaged my plugs . I had 3 plugs missing out of the 8. The issue with mine is lack of tunning.
Old Sep 29, 2008 | 11:31 PM
quik406's Avatar
Describe tuning?
Old Sep 29, 2008 | 11:33 PM
Ls1Gummi's Avatar
Originally Posted by quik406
Describe tuning?
Tuning as in he/we got a bullshit shitty *** nitrous tune.
Old Sep 29, 2008 | 11:35 PM
quik406's Avatar
Ya lost me. Once again. Describe tune?
Old Sep 29, 2008 | 11:41 PM
Ls1Gummi's Avatar
Man not to be rude or anything but do you even know whats going on?? Just go back to post 1 and read
Old Sep 29, 2008 | 11:44 PM
quik406's Avatar
Sorry your smart, Im dumb. Oh wait my plugs nver looked like that! I was trying to help. I don't think you understand tune. Thanks all I will Leave. Good luck.
Old Sep 29, 2008 | 11:47 PM
Ls1Gummi's Avatar
Well me and rob just said we got fucked up tunes what else it there to explain???
