Nitrous noob....what caused this?
check your jets there... according to them u have a 175 shots in there... which means you need to take another 2 degrees of timing out
So yes, the TR6s will work with a 150 (with a closer gap like .030"), but the whole tune better be "shot-on".
2nd, when describing a "Fucked up tune" was it done on a dyno, or was it a mail order tune?
3rd there are many different octanes available at pumps, what octane fuel are you running? I would hope that no one would run less than 93 anyways, ESPECIALLY on spray.
4th. What injectors are in the car?
I would suggest pulling 2 more degrees of timing and getting the car on a dyno for a decent tune. I would NEVER trust a mail order tune, especially on a car with power adders.
Really? My car will speckle a TR6 on the motor with 27* of timing, so your telling me they will be MORE than enough for a 150 shot?
What do you suggest for a 300 shot? TR7's
Thanks alot for all the info guys. BTW I'm running an Innovate LC-1 wideband, thats where Im getting my a/f's from. I just bought a set of TR8's and did a compression test. Highest cyl is 181 and lowest is 179 so I know the motor is fine. Well see how it does on TR8's with cam2.
So with stock compression, and a 150 wet shot, that's exactly what I'm saying. They are suffucient enough to run fine with a correct tune.
Maybe thats the reason you dont own it anymore.
I have seen a few dyno pulls made one time..... So how much HP is someone giving up running TR8's instead of TR6's on a 150 WET shot?
Easy Wayne!! You can't pound your advice into folks...Sometimes seeing is believing...and some people don't mind seeing melted parts.
Maybe this will calm you down..I just nabbed my first 250R! First 2 poke also...295cc(72mm), carb, fmf exhaust, 86 but red plastics, +2, +6 rear...
All I'm saying is I'm stating my experience with several cars, your stating your experience with 1 car. And that's all I have to say about that. Case closed.
Badass! ....Best Quad ever built !! Mine had a Duncan Racing 340 powervalve motor.
1 car? LMAO !!! Look up the 2007 Pump gas drags winner.... we built it in my garage along with quite a few other LS1 nitrous cars.
Now Mr. Dyno could you please answer the question... How much power are these guys giving up running TR8's instead of TR6's on a 150 shot (wet or Dry)?? .... My guess would be 1% So on your 500 hp car it might cost you 5 hp.
So I thnk I'd give up 5hp and not have to worry about posting pics of plugs with the straps burned off ..... JMO
I'm not the one wanting to engage in a pissing match here, or feel I have to prove anything. And yes, I agree, it never hurts to be on the safe side for no more of a loss than it would result in, but the simple fact is, the plugs did not cause the problem. And another fact is, that Tr6's are sufficient to handle stock compression with a 150 shot. PERIOD. I am done with this thread..
