9" screaming at me!
9" screaming at me! / FIXED
I have a brand new 9" with aluminum center section that is screaming at me. I don't know what is wrong with it. I have taken it to my local speed shop, they are very familar with 9" rear ends but even when they put a new ring and pinion it still is making a HUGE amount of noise. They gave it back to me because some other work needed to be done with it, so I took it because the gears had quiten a little bit. But after about 5 miles on them it started screaming at me again. The gear vendor says the interior needs to be back in the car to determine if itz too noisy. I have sound deadener in it but no carpet, this thing is REAL LOUD, I don't think carpet is going to do anything.
My question is do you set up an aluminum center any differnet than a nodular or cast center section? Any help or suggestions are welcomed.
ok
Has anybody ever had the center be off, itself? Two different gear sets, same obnoxious noise, has to be something different to me. HELP?
The sound is both going up and down(accel and decel).It resonates sometimes too, as far as checking the sweep, I don't know I will ask them that on Monday. After my intial 5 mile run on the gears, me and my buddy put the car up on the lift just to make sure there was fluid in the damn thing, it was, and the center section was hot enough to fry an egg. This is the second set of gears in it, both of them made an incredible amount of noise. They are 4.10 gears and I'm not sure of the manufacturer but I will ask about that on monday to and post that information.
from what I remember there was no difference.
difference was if you were running slicks the the feathering would be closer to the inside as opposed to street will be pattern in the middle.
as for it running hot it shouldn't be hot enough to fry an egg.
something is definately not right about that.
Obviously you should not have such a loud rear, most of the Moser rears are pretty quiet, not screaming as yours is. Contact the vendor you bought it through and have them take care of getting the center section sent in to Moser to have it inspected. Bob
as gear is US I think they are 2 cut gears and should be setup with a differant pattern from a reg 5 cut gear , just a question you may like to ask your setup person
good luck, Johnny
good luck, Johnny
