compatability question 00 vette computer/99 fbdy harness
Location: sneaking in your back door as you leave!/cartersville ga
need an answer quick. so yes u=i know were the search button is
i searched but barely. all the pinouts look the same, but it seems there are a few extra on the vette computer? how compatible are they as far as plug and play? i just dont want to get into a pinout changing party
oh and thanks in advance
greg
greg
sawzall wielding director
Should be plug and play. The vette and F-body PCM`s are the same hardware for those two years/applications. The only difference is in the programming, so at worst it will work just fine if you have the PCM reflashed as a f-body PCM
do you remember offhand which wires were different? If it was just sensor grounds and 5v references it will work fine even if it still has the vette programming in it.
i believe it was just 5v ref. and sensor grounds. and of course the dbw throttle stuff.
thanks for the quick answer. its bought and on the way!
LOL. I actually have all of my wiring diagrams saved to an external HD, but the USB ports on this computer no longer work so I haven`t been able to reload them.
I do have a lot of wiring info in the stickies, but I had a bunch of other wiring diagrams on the computer that were too big to upload to the stickies.
