upgrading head bolts?
Old 10-08-2008, 09:45 PM
Gregorya24's Avatar
Default upgrading head bolts?
i got the heads off my car cause i had a lifter go bad, would it be a good idea to upgrade the head bolts or just run some new stock gm bolts, im probably gonna spray a 100-200 shot depending on the mood! lol
Old 10-08-2008, 10:10 PM
=ZoomZ='s Avatar
ARP Head Studs dumdumdum .
Stock GM TTY head bolts will not hold down the heads on a 200 shot .
Old 10-08-2008, 10:27 PM
myfast70's Avatar
Go with ARP head bolts at minimum! Are you leaving the short block in the car? If so the heads studs will be a no go due space constraints.
Old 10-09-2008, 04:59 AM
Beer99C5's Avatar
ARP Head bolts here. If your gonna be playing with the car and changing up configurations its good idea to get reusable head bolts.
Old 10-09-2008, 06:07 AM
dawiz's Avatar
another question about head bolts. i did ported ls6 heads. when i did the install i used arp head bolts. does anyone recommend retourqing the bolts?
Old 10-09-2008, 07:28 AM
=ZoomZ='s Avatar
I always do .
Heat cycle the motor like 10 times and retorque .
Old 10-09-2008, 09:41 AM
Nick@HSW's Avatar
Definitely make the switch if you plan on running a 200 shot.
Nick
Old 10-09-2008, 11:39 AM
Sprayed 99's Avatar
you can put studs in with the short block in the car. i did and its a pain in the *** but worth it
Old 10-09-2008, 02:15 PM
myfast70's Avatar
Would be worth it but as long as it would take to put them in it may be quicker to drop the whole cradle.
Old 10-09-2008, 02:20 PM
JScamaro's Avatar
I would run ARP head studs. I have them on my H/C and nitrous setup.
Old 10-09-2008, 04:34 PM
BarneyMobile's Avatar
Its really not that bad to do head studs in the car. I run arp head studs on my car and it wasnt that bad to do in the car. Space is alittle tight on the passenger side, but the easiest way to do it in the car is to leave the back 4 studs out on the passenger side then sit the head on the block. Afterwards you and reinstall the back 4 head studs.
Old 10-09-2008, 04:38 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Head studs or wait to save money to buy them. Just for the simple fact of never having to clean the head bolt holes ever again.
Old 10-10-2008, 09:42 AM
Sprayed 99's Avatar
its cake on the drivers side. on the passenger side leave the back 4 studs out and when you go to drop the head on put the stud thats farthest back and on the bottom inside that hole. if not you'll never get it in after the head is on the engine
Old 10-10-2008, 09:50 AM
TARV's Avatar
Anything over a 100 shot should have head studs!
Old 10-10-2008, 01:57 PM
=ZoomZ='s Avatar
