Gxp Motor Mount Flip
Old 01-01-2009, 07:28 PM
estical79's Avatar
Default Gxp Motor Mount Flip
Does anyone have instruction (pics) of how to do the motor mount flip. I think i have understood what i have read, but really don't want to screw anything up. Ive got that black cloud that follows me around. Lastly, is there a prefered mount to use when reinstalling? Thanks
Old 01-01-2009, 07:51 PM
neilownz's Avatar
i havent done the flip, but i know its quite a pain to get the old piece out if you want to install a poly or MSP “TBv2” mount. unbolt the mount part from the car, put it in a vise, use alot of wd40 and a long flat screwdriver. i tried cutting mine and it ended up being alot of extra work.
the flip is basically you keep the mount installed in the car, put the bolt in without the dogbone, tighten the bolt, lube it and then try and rotate it 90 degrees by tightening it more until it moves.
Old 01-01-2009, 11:02 PM
Nacho SS's Avatar
The MSP3800 mount is a good investment unless you drive a lot in could weather. Others have reported that that mount is a little rougher than the stock mount.
Old 01-02-2009, 09:39 AM
neilownz's Avatar
im using the zzp poly one and its kinda cold here. ride isnt that bad really.
http://www.zzperformance.com/grand_p...=130&catid=138
can select just one mount.
Old 01-03-2009, 12:41 AM
StealthV8's Avatar
http://www.clubgp.com/newforum/tm.as...de=&s=#2110673
Quick Reply: Gxp Motor Mount Flip
