help with replacing antifreeze/coolant
Old 07-07-2009, 05:43 PM
Sittingmongoose's Avatar
Default help with replacing antifreeze/coolant
i am adding royal purple's purple ice to my coolant. I talked to tech support and they said to drain out about 2 pints of coolant, add the purple ice, than fill back up with straight water. I have two questions though. Where is the resoviar drain and should i use water from my house hose? or like filtered water?
Old 07-07-2009, 07:51 PM
Panther427's Avatar
Filter water. Water from the tap still contains more minerals which a quart of wont really hurt, but over time the mineral content could add up.
Old 07-08-2009, 12:24 AM
texasGXP08's Avatar
Distilled water from the store is best, comes in the gallon jugs.
Old 07-08-2009, 07:51 AM
The other problem i was having was that i cant find the radiator drain. Is it covered up or something?
Quick Reply: help with replacing antifreeze/coolant
