Factory Catalytic converter size
Old 07-12-2009, 10:47 PM
AlabamaGuy's Avatar
Default Factory Catalytic converter size
Can anyone give me the dimensions of the factory cat, as well as inlet/outlet sizes? A PN for a high flow replacement would work too if anyone's done the research
Old 07-13-2009, 11:49 AM
AlabamaGuy's Avatar
bump for info
Old 07-13-2009, 11:53 AM
Panther427's Avatar
2.5" high flow cat.
Old 07-13-2009, 12:09 PM
AlabamaGuy's Avatar
Originally Posted by Panther427
2.5" high flow cat.
length?
Old 07-13-2009, 01:48 PM
Panther427's Avatar
no idea
Old 07-13-2009, 03:45 PM
Mgpeagle's Avatar
Are you just going to replace the factory cat that is on the car now without replacing the downpipe too? To be honest, I'd replace both since the factory down pipe is restrictive too. The factory cat flows pretty good.
http://www.hoganperformance.com/DP7S.htm
http://www.hoganperformance.com/converters.htm
-Mike
Old 07-13-2009, 08:14 PM
AlabamaGuy's Avatar
I was going to buy the shorty DP and replace the factory cat. I just can't see spending $300 for a 3 ft piece of pipe and a converter. I don't know though, maybe you guys can convince me? What kind of dyno proven results are you getting with the full catted DP?
Old 07-14-2009, 12:12 AM
Red03GT's Avatar
Don't want to go catless? I picked up ~5mph on the traps from a cutout & catless DP.
Old 07-14-2009, 10:28 AM
Panther427's Avatar
Just buy the cat and down pipe he offers seperat. its alot cheaper.
Old 07-14-2009, 02:32 PM
AlabamaGuy's Avatar
That's what I was thinking.
Don't want to go catless because of the warrantee.
Old 07-14-2009, 10:08 PM
EmersonHart13's Avatar
I would keep the cat and get the dp and u bend removed at a local shop.
That is of course if I did it again...
Old 07-14-2009, 10:23 PM
AlabamaGuy's Avatar
Do we have a U-bend?
Old 07-15-2009, 02:38 AM
TheMonteMan's Avatar
not that i know of.
Old 07-15-2009, 10:23 PM
AlabamaGuy's Avatar
Originally Posted by TheMonteMan
not that i know of.
On the rack today at the exhaust shop...we have a u-bend.
Old 07-15-2009, 10:48 PM
Red03GT's Avatar
What u-bend are you guys talking about? I don't see what you guys mean on the stock downpipe...or on the hogan dp either.
Old 07-15-2009, 10:55 PM
AlabamaGuy's Avatar
Down pipe comes off the crossover pipe and houses a cat and O2 sensor. the U-bend is a tight bend to move the O2 sensor away from the floor. Hogan Performance makes a high flow version.
Old 07-15-2009, 11:59 PM
LS1Tech Sponsor
06MonteSS's Avatar
the u-bend isn't gonna gain you anything... don't worry about it...
had 4 exhaust pro's look at it on my Monte, and all of them said it wasn't an issue... the bend was so sllight, removing it isn't going to gain you anything...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 07-18-2009, 03:10 PM
AlabamaGuy's Avatar
If the dealer plugs the car up to a diagnostic machine, will they be able to tell that the rear O2 sensor was tuned out, or that the cat has been gutted?
